Although Amazon Music is not currently built into any of our units, you can still play content from your Amazon Music account to your 851N.
AirPlay
You can stream from Amazon Music to your 851N using AirPlay from a compatible Apple device.
Choose More Devices and select the Apple AirPlay icon from within Amazon Music. Apple AirPlay supports a maximum sample rate and bit depth of 44.1kHz/16bit.
USB Audio from PC or Mac
The Amazon Music desktop app can also be played from your PC or Mac via a USB Audio connection to your 851N.
Connect a USB A to B cable between your PC or Mac and the 851N and select USB Audio as the desired digital input through the 851N's interface.
Bluetooth (aptX)
Audio can also be played over a Bluetooth connection available by connecting the optional BT100 Bluetooth receiver and pairing it to your smart device.
