There are a few different ways of using TIDAL with Evo. Evo includes TIDAL Connect integration, as well as the ability to utilise TIDAL within our StreamMagic app.
TIDAL Connect
1. Ensure that Evo and your device are connected to the same Network.
2. Open TIDAL app
3. Select the song/album/playlist you want to play.
4. Click on the 'Now Playing' bar.
5. Click on the 'Sound Output' icon.
6. Select Evo 75/150 (TIDAL Connect).
StreamMagic app
1. Ensure Evo and your device are connected to the same Network.
2. Open our StreamMagic app on your device.
3. Ensure Evo is recognised by the StreamMagic app.
4. Select the 'Library' tab, then select 'TIDAL'.
5. Log in to your TIDAL account.
6. Select the music you want to play within one of the following categories. This will then stream TIDAL to Evo.
Apple AirPlay
2. Open the TIDAL app on your Apple device.
3. Select the song/album/playlist you would like to play.
6. Select "AirPlay & Bluetooth".
7. Select Evo 75/150 in your list of AirPlay devices.
Chromecast
2. Open the TIDAL app on your Chromecast enabled device.
4. Click on 'Now Playing' bar.
6. Select Evo 75/150 under Chromecast.
Bluetooth
1. Open your device's Bluetooth settings.
2. Select Evo 75/150 from the device list.
3. Open the TIDAL app on your Bluetooth enabled device.
4. Select the song/album/playlist you would like to play.
5. Click on the 'Now Playing' bar.
6. Click on the 'Sound Output' icon.
7. Select the Evo75/150 as a Bluetooth device.
For further information on TIDAL Connect, please visit TIDAL's website: tidal.com/connect
