You can assign your favourite radio stations, playlists, albums and songs to presets on your Evo 75 and 150 using the StreamMagic app. Using the StreamMagic app will allow you to store and manage up to 20 presets.
Please note that you will only be able to save playlists, albums and songs when using Spotify Connect. Other integrated streaming services, UPnP, etc. do not allow this feature.
Step 1: Stream a radio station, playlist, album or song to your Evo unit via the StreamMagic app, then return to the playing screen on the app and press the three vertical ellipsis dots if using an iPhone as shown.
If using an Android device, please select from the option button in the top right corner as shown.
Step 2: Upon selecting the ellipsis dots (iPhone) or option button (Android), you will have the option to 'Add to presets' as pictured below.
Step 3: You will then be presented with the option to assign the content to a preset of your choosing as below. Please select the number you wish to assign to.
Step 4: Once the content is assigned to your preset of choice, you will receive confirmation of this.
These settings can also be adjusted via the StreamMagic app under the 'PRESETS' section, where you can remove any unwanted presets.
