Relevant Products: EVO 75/150, Edge NQ, CXN (V2) and Azur 851N.
Although Amazon Music is not currently built into any of our units, you can still play content from your Amazon Music account to your network player.
AirPlay
You can stream from Amazon Music to your network player using AirPlay from a compatible Apple device.
Choose More Devices and select the Apple AirPlay icon from within Amazon Music. Apple AirPlay supports a maximum sample rate and bit depth of 44.1kHz/16bit.
Chromecast
You can stream from Amazon Music to your network player using Chromecast from a compatible Chromecast device.
Choose More Devices and select the Chromecast icon from within Amazon Music. Chromecast supports a maximum sample rate and bit depth of 96kHz/24bit.
Note: This excludes the 851N which does not contain built-in Chromecast.
USB Audio from PC or Mac
The Amazon Music desktop app can also be played from your PC or Mac via a USB Audio connection to your Cambridge Audio network player.
Connect a USB A to B cable between your PC or Mac and the Cambridge Audio network player and select USB Audio as the desired digital input through the network players’ interface.
Bluetooth (aptX)
Audio can also be played over a Bluetooth connection available by connecting the optional BT100 Bluetooth receiver, or using built-in Bluetooth from the Cambridge Audio network player and pairing it to your smart device.
