You can assign your favourite radio stations, playlists and albums to presets on your network player, using both the remote control for your unit, or the Stream Magic app.
Storing Presets using a Remote Control:
To save a radio station using your remote control, simply play the station, press and hold one of the numbers (1-8) on your remote control and the station will store to that preset.
For example when listening to BBC Radio 1, if you press and hold '1' on your remote control, it will assign that station to that preset. This can also be done when playing your favourite playlists or albums.
Storing Presets using the StreamMagic app:
Using the StreamMagic app will allow you to store and manage up to 20 presets.
To do so, please open your streaming service of choice via 'MUSIC APPS' within the StreamMagic app. Stream a playlist or album to your network player, then return to the playing screen on the StreamMagic app and press the three vertical ellipsis dots as shown.
Upon selecting the ellipsis dots, you will have the option to 'Add to presets' as pictured below.
You will then be presented with the option to assign the content to a preset of your choosing as below. Please select the number you wish to assign to.
Once the content is assigned to your preset of choice, you will receive confirmation of this.
These settings can also be adjusted via the StreamMagic app under the 'PRESETS' section, where you can remove any unwanted presets.
