Your Cambridge Audio product warranty is the responsibility of the retailer or dealer that you purchased from.
If you purchased from Cambridge Audio directly via Cambridgeaudio.com or our Amazon stores:
Cambridge Audio products are covered by a warranty from the date of purchase which may differ based on the region it was purchased. This does not cover above-average wear and tear, misuse, and abuse.
Melomania:
- 2 years warranty on earbuds and charger.
- 1-year warranty on batteries.
- 6 months extra warranty when registering your product at https://www.cambridgeaudio.com/gbr/en/register
Electronics, Disc Players, Speakers, TV Speakers, Wireless Speakers and Remotes:
- 2 years warranty
For U.K customers who purchased from Cambridge Audio directly via our eBay store:
The warranty is specified on each individual listing.
What is covered by a Cambridge Audio warranty?
The warranty covers the repair or replacement (at Cambridge Audio’s discretion) of your Cambridge Audio product if it is found to be defective due to faulty materials or workmanship within the warranty period.
If any part is no longer available (e.g. particular colour variations), Cambridge Audio will replace it with a functional replacement part. Please be aware that due to the age of some devices this may not always be possible, in which case we will contact you directly to discuss further options.
What isn't covered by a Cambridge Audio warranty?
Above-average wear and tear
Accidental damage
Faults caused by:
The terms and conditions of a Cambridge Audio warranty are as follows:
The warranty becomes effective at the date of purchase (or the date of delivery if this is later).
You must provide proof of purchase before any work can be carried out on your product under the warranty. Please note that without this proof any work carried out will be chargeable. Please keep your purchase receipt.
All work will be carried out by Cambridge Audio or its authorised agents.
Any parts which are replaced will become the property of Cambridge Audio.
The repair or replacement of your machine under warranty will not extend the period of the warranty.
The warranty provides benefits that are additional to and do not affect your statutory rights as a consumer.
Where is the Cambridge Audio warranty valid?
This warranty will only be valid if the product is used in the country in which it was sold.
If you take your product abroad the warranty may be invalidated. However, we will do our best to help you in your new country of residence.
Are Cambridge Audio warranties transferable?
Cambridge Audio warranties are transferable with the product, provided the original proof of purchase from Cambridge Audio is supplied, together with evidence of any change of ownership of the machine, confirming that the machine was in good working order when the change of ownership took place.
IMPORTANT:
If you purchased from a retailer or dealer please contact them for warranty information.
