The Edge NQ, 851N and CXN v2 are now fully compatible with Roon and they will function as Endpoints in a Roon system. This means that you will need both a Roon Core and a Roon subscription for the system to function. None of our streamers will function as a Roon Core.
To add your Cambridge Audio streamer to a Roon system.
· Ensure it is connected to the same network and switched on.
· Go into Settings/Audio in Roon.
· The Cambridge Audio streamer should be seen as a Roon compatible device
· Press Enable.
The Cambridge Audio streamer can now be selected from the list of devices in your Roon system
