Presets can be used to save radio stations, custom URL streams, Spotify playlists and even external sources.
Edge NQ - External Sources and volume
When you save an external source as a preset the current volume is saved with the preset. This allows you to recall the perfect listening volume for your external sources.
Tip: If you don't want to save the volume with your external source preset, set the volume to zero before saving the source as a preset. When you recall the preset the volume will be unchanged.
Notes:
- If you recall a source preset with headphones attached the volume remains unchanged.
- If your Edge NQ has Preamp Mode disabled, the volume setting will be ignored.
Comments
