Third party foam tips for Melomania 1
For those looking for a third party foam tip for the Melomania 1 we have found the Comply T-600 Size; Medium foam tips will fit the Melomania 1 earbuds.
Please be aware that due to their size you will need to make sure that they are pushed down firmly and securely in the case to ensure they connect with the pin in order to charge properly, as they will be a snug fit.
They can be found on the Comply website here,
or on Amazon here.
