When a Firmware update is available for the EDGE NQ the Edge Remote app will provide you with a notification.
In iOS the 'More' icon will appear with a red circle.
Red circle over More icon (iOS).
In Android a blue popup will appear above the tab bar at the bottom of the app.
Firmware pop up box (Android).
To update the firmware within iOS you will need to navigate to More>Settings where the firmware update is available to select and download at the top of the settings list.
In Android clicking 'UPDATE',within the blue popup, will automatically bring you to the settings page where the firmware update is again at the top of the settings list.
iOS Settings Page Android Settings Page.
Once you have selected 'New Firmware available' The Edge NQ will start downloading the update.
