022-a-123
- Added Media Player presets.
- Updated Spotify Connect.
- Updated TIDAL Connect.
- Updated AirPlay.
- Improved AirPlay multi-room sync.
- Fixed AirPlay sample rate/bit depth not being displayed.
- Fixed a crash when playing RNE clasica radio station.
- Fixed (SR) Swedish Radio audio dropouts.
- Fixed balance control settings after a network standby power cycle.
- Added fixes to support the mini-player in the Android SM App.
- Added Home Theater Bypass for Edge NQ
- Added HiDef Chromecast support for CXNv2/s2 and Edge NQ
- Fixed a unit crash when adding tracks to the queue
- Fixed broken PBB internet radio streams
- Fixed entering Network Standby during Bubble UPnP queue playback
- Fixed adjusting the display brightness when in Network Standby.
1st September 2021
- Fixed Spotify long album name metadata scrolling on the front panel display.
- Fixed a crash when quickly skipping through tracks in the queue using the IR remote control.
- Fixed album art not displaying from a USB drive when the streamer is off-line.
- Fixed Cambridge Connect transport controls on CXR.
1st July 2021
- Fixed a TIDAL Integrated audio dropout when skipping AAC tracks with a premium subscription
- Fixed a Cast authentication issue that caused Cast to stop working for some users
- Changed "play-from-here" behaviour to clear the current queue before adding new tracks
- Fixed playback pausing between tracks when using 3rd party UPnP control points.
- Fixed CXR power on/off via the SM App
- Fixed CXR IR remote control transport buttons
- Increased maximum number of presets from 20 to 99
- Fixed metadata reporting for Control4/RTI systems
- Removed 50th anniversary Cambridge Audio logo from the webmin settings page
- Improved initial setup process
- Updated "Edge Remote" app references to "StreamMagic"
- Updated webmin device settings headings
- Fixed playback when selecting specific tracks from the queue on CXR
- Fixed mDNS broadcasting after changing the device name and then rebooting
26th April 2021
Improved TIDAL Connect stability.
Fixed occasional pops and clicks at the end of some DSD tracks.
Fixed German translation for "Skip" which prevented users from completing setup.
Fixed playback of invalid or corrupted .dsf files
NB: Please be aware that once updated your device will no longer support browsing TIDAL from the front panel Library of the device or from the Cambridge Connect app.
This is because accessing Tidal via the front panel and through the Cambridge Connect app uses an older method of log-in that Tidal is phasing out for security reasons. In order to be able to make use of the functionality of Tidal connect we have therefore had to remove access via these methods at Tidal's request. The more modern log-in method in the StreamMagic app is much more secure.
We do apologise for any inconvenience that this may cause.
22nd March 2021
v022-a-043
- Added TIDAL Connect.
- Fixed various broken Internet Radio streams.
- Improved webmin translations.
v018-a-078
30th June 2020
Features:
- CXNv2:
Fixed expiring Qobuz URL's after playback is paused for long periods of time.
v018-a-075
9th April 2020
Features:
CXNv2
- Updated Roon RAAT SDK to 1.1.37
- Fixed DSD sample rate reporting when playing DSD files over digital inputs.
- Improved USB drive detection with the StreamMagic app.
28th February 2020
v018-a-062
Features:
• Added Roon Ready support.
• Added a QR code banner to direct users to the StreamMagic app download page.
• Added source description fields to the sources settings page.
• Updated translations.
• Added dark mode to the settings page for iOS devices.
Improvements:
• Fixed WAV + AIFF + DFF/DSD files played from USB drives from reporting 00:00 track length.
• Removed [All Stations] filter from Radio Genres search to reduce load times.
• Removed a 32 character limit when entering TIDAL username and password login details from the front panel.
• Fixed audio playback when coming out of Network standby with a queue action.
• Resized the Chromecast setup process for mobile devices with small displays.
• Fixed the progress bar from jumping after pausing and resuming playback when Casting Spotify.
v017-a-070
Features:
• Add support for Qobuz (StreamMagic App required)
• Add support for Spotify Free.
• Add repeat track (repeat-1) functionality to Spotify Connect.
Improvements:
• Improved Spotify preset handling.
• Fixed AirPlay audio glitch when switching between AAC tracks.
• Various Webmin updates.
• Fixed CBUS power-on commands when unit starts up in ECO mode.
• Fixed MCU Error messages appearing when upgrading some units.
• Added translations for "ECO mode" in Dutch and Polish.
• Added new StreamMagic splash-screen to unit start-up.
• Replaced old Cambridge Connect app icons with new StreamMagic app icons
9th October 2019
v016-a-077
Improvements:
- New Webmin interface with language support.
- Updated Dutch and Polish translations.
- Improve the front panel menu transition when switching to Radio.
- Fix a rare crash when quickly switching between presets.
- Move CBus control to the unit device settings, instead of the companion app.
9th May 2019
v014-a-140
Improvements:
- Fix the end of some tracks being cut off.
- Improved playback on low bit-rate MP3 files over UPnP.
- Fix for removing pre-sets via Webmin.
- Fix to prevent Alva TT+BT100 getting stuck in a stopped state.
22nd January 2019
v014-a-109
Improvements:
- Fix some USB drives not being detected.
- Fix a rare crash when setting the language and then immediately changing preamp mode.
- Fix to stop adding previously deleted queue items to the queue after changing the shuffle state.
- Fix to ensure that the next track is played after deleting the current track in the queue.
- Fix Apple Wireless Accessory Configuration for users connecting to hidden networks.
- Fix to remove track length restrictions on High-resolution WAV files larger than 2GB.
20th November 2018
v014-a-089
Improvements:
- Fix for APEv2 support.
- Fix for artist & track titles from internet radio stations not displaying on Connect App when using CXNv2.
- Fix for front panel still illuminated when unit is put in standby by remote app.
- Fixed crash when going to network standby while USB drive is mounting.
- Improved Audirvana support - better synchronisation with Mac app.
24th September 2018
v014-a-081
New Features:
- Chromecast built-in support
- Added option to remove TIDAL from Library
Improvements:
- Fixed issue with CXN,851N, SM6v2 pausing at the end of a track
- Fixed issue with playlists appearing in incorrect order
- Fixed issue with ‘Play from here’ on USB drive
- Translation updates
3 April 2018
v102-a-471
Features:
- TIDAL support
- 50th anniversary boot splashscreens
Fixes:
- Performance improvements
- Fix duplicate information when browsing some UPnP servers
- Handle UTF-8 characters when fast-scrolling through menus
- Fix random crashes when getting SNTP time-sync
13 December 2017
v102-a-428
Internet Radio improvements:
- Add search
- Display now-playing icon on currently selected stream
- Improve sorting, speed up browsing
- Display progress when loading long list of radios
