This driver enables you to use your CXN in USB Audio Class 2 alongside your Windows PC.
This new version adds compatibility with Windows 10 and can be used on the following operating systems in both 32bit and 64bit:
- Windows 7 that has the latest updates installed (specifically Microsoft Security Advisory 3033929)
- Windows 8
- Windows 8.1
- Windows 10
Older versions of Windows 7 and earlier operating systems are not supported and you will need to use the v1.67 or v1.43 driver.
All instructions on how to install this driver can be found within the PDF file in the attached folder.
Please Note: If you are running a previous version of this driver without any issues you will not need to download this driver.
For more information on USB Audio please follow this link here to the USB Audio page.
