Relevant Products: EDGE NQ
A Bluetooth connection is available on the EDGE NQ by using the included Bluetooth Antenna and selecting the Bluetooth source input.
If using an aptX HD enabled audio device you will be able to achieve 24-bit 48KHz streaming and wirelessly stream Hi-Res audio files such as FLAC. If your device is not aptX HD or aptX enabled you will instead be using the standard SBC Bluetooth codec.
