To disable or adjust APD on the EDGE NQ you will need to download and install the Edge Remote app on your phone or tablet.
Once download you will need to navigate to the menu in the top right and select settings.
Here you will see an option for 'Auto power down', once clicked you will be able to adjust the APD time or disable it altogether.
Comments
