Relevant Products: YOYO (L), Air 200 V2, Air 100 V2
All of our Wireless Speakers are Spotify Connect enabled. This means as long as you have a Spotify premium subscription you will be able to stream all of your music from your Spotify account directly to your speaker.
Please find instructions on how to use Spotify Connect below:
Desktop
- Open Spotify and play something.
- Click Connect to a device
in the bottom-right.
- Select the device you'd like to play on.
Mobile/Tablet
- Tap Devices Available at the bottom of the screen.
- Tap the device you want to play to.
Not seeing the device you want in the device list?
Try switching off the Show local devices only setting. This means your app will try to find nearby devices that aren’t on the same internet connection as you. Here's how:
- Tap Home
Got Premium? Tap Your Library.
- Tap Settings
- Tap Devices.
- Switch off Show local devices only and try Connect again.
As well as using Spotify Connect you can also use the following methods to listen to Spotify.
Apple AirPlay (Only available on the Air Speakers)
You can play any streaming service on your Speaker using AirPlay from a compatible Apple device.
Choose “More Devices” and select the Apple AirPlay icon from within your chosen App, Control Centre or iTunes (PC/Mac) and select your Speaker.
Bluetooth
Audio can also be played over a Bluetooth connection available by selecting the Bluetooth input and pairing it the speaker to your smart device.
Cast (Only available on the YOYO (L) )
You can play any streaming service on your YOYO (L) using Cast from a compatible Android device.
From within any streaming app simply tap the icon where you should be able to select the YOYO (L).
For more information please visit Spotify's support site here.
