Relevant Products: EDGE A
A Bluetooth connection is available on the EDGE A by using the included Bluetooth Antenna and selecting the Bluetooth source input.
If using an aptX HD enabled audio device you will be able to achieve 24-bit 48KHz streaming and wirelessly stream Hi-Res audio files such as FLAC. If your device is not aptX HD or aptX enabled you will instead be using the standard SBC Bluetooth codec.
