Here at Cambridge Audio, we’ve been working hard to make your Edge NQ experience even better! There is a new firmware update.
The next time you switch on your EDGE NQ it will automatically see that an update is available and will prompt you to update. Alternatively, you can update your device manually by going to Settings within the EDGE remote app.
Please Note: Edge NQ users with preamp mode switched off will need to re-apply this setting after the update.
19th April 2022
General Release 022-a-124 is now available.
- Updated Cast.
- Fixed Casting BBC Sounds.
- Fixed Casting Deezer.
- Fixed Casting YouTube Sounds.
