Although Deezer is not currently built into any of our units, you can still play content from your Deezer account to CXN (V2).
AirPlay
You can stream from Deezer to your CXN (V2) using AirPlay from a compatible Apple device.
Choose More Devices and select the Apple AirPlay icon from within Deezer. Apple AirPlay supports a maximum sample rate and bit depth of 44.1kHz/16bit.
Chromecast
You can stream from Deezer to your CXN (V2) using Chromecast from a compatible Chromecast device.
Choose More Devices and select the Chromecast icon from within Deezer. Chromecast supports a maximum sample rate and bit depth of 96kHz/24bit.
USB Audio from PC or Mac
The Deezer desktop app can also be played from your PC or Mac via a USB Audio connection to your CXN (V2).
Connect a USB A to B cable between your PC or Mac and the CXN (V2) and select USB Audio as the desired digital input through the CXN (V2)’s interface.
Bluetooth (aptX)
Audio can also be played over a Bluetooth connection available by connecting the optional BT100 Bluetooth receiver and pairing it to your smart device.
