Aptx enabled Wireless Speakers - Air V2, Bluetone 100
A Bluetooth connection is available by selecting the Bluetooth input on your speaker and pairing the Wireless Speaker to your smart device. This will allow you to stream audio from any phone or tablet to your unit.
For detailed pairing instructions please read the Quick Start Guide which came with your Cambridge Audio Wireless Speaker.
Upon selecting the Bluetooth input on your Wireless Speaker you should notice the Bluetooth LED on the change to Blue.
If using an aptX enabled audio device you will be able to achieve 16-bit 44.1KHz streaming and be able to wirelessly stream Hi-Res audio files such as FLAC. If your device is not aptX enabled (such as the YOYO range of Wireless Speakers) you will instead be using the standard SBC Bluetooth codec.
