Aptx enabled TV Speakers - TV2 (V2), Tv5 (V2)
A Bluetooth connection is available by selecting the Bluetooth input on your TV remote and pairing the TV speaker to your smart device. This will allow you to stream audio from any phone or tablet to your unit.
Upon selecting the Bluetooth input on your TV Speaker you should notice the LED on the front change to Blue. On the TVB2 and TVB2 (V2) 'Bluetooth' will appear along the front of the unit.
If using an aptX enabled audio device you will be able to achieve 16-bit 44.1KHz streaming and be able to wirelessly stream Hi-Res audio files such as FLAC. If your device is not aptX enabled (such as the TVB2 V2) you will instead be using the standard SBC Bluetooth codec.
Comments
