Relevant Products: Yoyo (L)
Google's Cast function lets you stream audio from any device running a compatible app to your unit.
Many streaming services and apps will work with this function.
If you wish to use the Cast functionality of the Yoyo (L), you can do so by following the steps below.
- Connect your device to the same Wi-Fi network as your Chromecast Audio or speaker with Chromecast built in.
- Open the Google Home app
- In the top-left corner of the home screen, tap Menu
> Cast Screen/audio
- Select your Yoyo (L).
