Relevant Products: Azur 851C
What is a Pre-Amp?
Digital Wave Analogue Wave
How does this relate to my Network Player?
For this reason, when Digital Pre-Amp (DPA) mode is switched on, the volume control of your Network Player becomes active, allowing you to control the output of your unit. This, in turn, prevents the Power amplifier from delivering a full signal to your speakers and damaging them.
If you wish to use one of our Network Players as a Digital Pre-Amplifier we have a few tips to prevent damage or confusion regarding your system.
- DPA mode is NOT enabled upon initial set-up of the Network Player and as such must be enabled before connecting to a power amplifier. Failure to do so may result in speaker damage.
- When you attempt to enable DPA Mode, we would advise switching this feature on before connecting the Network Player to your Power Amplifier. If you have already connected the devices, please ensure there is no audio playing through your system.
- Please check the volume of the Network Player is initially set to a low level every time you use the unit, before switching the Power Amplifier on.
- If at any point you wish to perform a factory reset on your unit, this will then disable Digital Pre-Amp Mode. This will, therefore, need to be switched back on before using your system.
- We would advise checking DPA is enabled after every firmware update as a precaution.
- If at any point you wish to connect an analogue device such as a turntable to your system, this will not be possible directly as there are no analogue inputs within the Network Player. You may use an Analogue-to-Digital converter although this can reduce the quality of the audio. This is because the signal will later need to be converted back to analogue to be sent to your speakers and the conversion can add audio distortion.
