If your DacMagic 100 was manufactured prior to 2014, you will require an update to enable USB Audio 2.0 compatibility.
You can tell when your DacMagic was manufactured via the serial number. The numbers in bold below indicate the year followed by the month. In this example, the unit would have been made in August 2013.
XX C10501 1308 0001
The DacMagic 100 firmware upgrade file can be accessed AT THE BOTTOM OF THIS PAGE.
Please note: This is for the DacMagic 100 ONLY. It is important this is not applied to any other version of DacMagic as this will cause a major failure and cause your unit to stop functioning.
Once you have installed the relevant updates, you will need to switch to USB 2.0 on the DacMagic.
To change USB Class on the DacMagic 100:
- Press and hold the Source button whilst bringing the unit out of standby.
- One of the digital input source LEDs will illuminate to indicate the current USB setting: S/P Dif 1 represents USB Audio Class 1.0, likewise S/P DIF 2 is USB Audio Class 2.0.
Depending on which version of Windows you are running, you will need to use a windows driver to ensure your PC or laptop continues to recognise the DacMagic. The latest USB Class 2 driver can be found here.
For more information on what driver to use please see here.
Please note: This driver update is not required for Mac users.
