The Yoyo (L) has the ability to learn your TV remote control volume commands.
This means you will only need one remote to control the volume for your Yoyo (L) when it is connected to your TV.
Please note: This feature is only necessary when using either the optical or 3.5mm Aux connections.
If using ARC for TV audio, there is no need to learn the TV remote control volume commands into the Yoyo (L). The TV sends these commands via the ARC connection.
To learn the Vol + button on your TV remote:
- Press and hold the
and + button on the Yoyo (L) for 3 seconds. The Volume indicator
will then countdown. - Press the Vol + button on your TV remote, remembering to point it at the Yoyo (L).
- The Volume indicator will then start flashing and you will need to press the Vol + button again on your TV remote to complete the process.
To learn the Vol - button on your TV remote:
and - button on the Yoyo (L) for 3 seconds. The Volume indicator
will then countdown. - Press the Vol - button on your TV remote, remembering to point it at the Yoyo (L).
- The Volume indicator will then start flashing and you will need to press the Vol - button again on your TV remote to complete the process.
When successfully learned, the volume level indicator will flash twice.
If it flashes red, this indicates that the remote learning has failed and you will need to start the process over again.
