How to perform a Factory Reset on the 851E
To perform a reset on the 851E, firstly you will need to turn the unit off using the power switch on the rear of the 851E. After the unit is turned off press and hold the mode button whilst turning the unit on again(using the rear power switch). You should now see 'RESET' displayed in the bottom right of the 851Es display.
