What cable is required for the RS232 connection on the CXR120 / CXR200?
The CXR AV receivers require a Straight Through cable from a DTE (Data Terminal Equipment), such as a computer.
When is a Null Modem cable required?
Normally the 'controller' (the DTE) has a male connector and the equipment being controlled (the CXR) has a female connector, so a straight through cable is required.
A Null Modem cable is used to connect two 'controllers' (and so is female at both ends with the RX/TX lines crossed over).
