How can I get my TVB2 to "learn" my television's remote?
Your TVB2 has the ability to learn your television's remote when using Optical or Aux connections.
  1. To learn the Vol+ button on your television's remote, press and hold the  and + button on the TVB2 for 2 seconds. "LEARN" and "VOL +" will flash on the display. Then double press the Vol+ button on your television remote, remembering to point it at the TVB2's display.
  2. To learn the Vol- button on your television's remote, press and hold the  and - button on the TVB2 for 2 seconds. "LEARN" and "VOL -" will flash on the display. Then double press the Vol- button on your television's remote, remembering to point it at TVB2's display.
When successfully learned, "OK" will be shown on the display.
Please note: If using HDMI-ARC for TV audio, there is no need to learn the television's remote control volume commands. The TV sends these commands via the HDMI connection.
1 out of 1 found this helpful
