Why isn't my remote control working?
There are a few reasons why your remote could not be working.
An IR Remote Control sends out a signal using Infrared light. You cannot see this light with the naked eye, however by using a Smart phone in camera mode you can see the signal.
  1. Open the camera app.
  2. Point the end of the remote control with the IR emitter at the camera lens.
  3. Look at the phone's screen.
  4. Press and hold one of the buttons on the remote control.
  5. If the remote control is sending a signal, you should see a light in the phone's screen when you press the remote's buttons.
If a light is present when no button is pressed, one of the buttons on the remote may be stuck and preventing other buttons from working. If this is the case:
  1. Remove the batteries.
  2. Press and release each button a couple of times to see if you can free the stuck button.
  3. Replace the batteries and test the remote again.
If you continue to see a light when no button is pressed, the batteries will require replacing.
If the remote still refuses to work, the entire handset may require replacement.
2 out of 5 found this helpful
