How Many Air Devices Can I Use On My Network At The Same Time?
You can connect as many Air units to your home network as you wish.  However, the Air app will only talk to one unit at a time, so you will need to manually switch between units on the app (using the Devices option within the app) to control each Air speaker as required.
