Why is the G5 making a 'beep' noise when I try to connect to it?
To pair your phone/tablet/computer with the G5, the mode switch on the rear of the unit must be set to 'A' (left position, if looking at the rear panel).
This should be set to the 'A' position as default, however it may have been changed to the 'B' setting accidentally.
The 'A and B' options are designed to enable two G5 devices to pair to one another. This enables simultaneous playback with two speakers.
1 out of 1 found this helpful
