When you originally set up your Air, you would most likely have connected it to your home network.
If you wish to connect it to a different network, there are a couple of ways to put the unit into the appropriate state:
- Press and hold the WPS button on the rear panel of the Air for approximately 7 seconds. The light on the rear panel will then flash Green and Orange to indicate the unit is in Network Setup Mode.
- You can also carry out a factory reset on the Air by holding the WPS button and the Standby button whilst the unit is in standby mode.
Note: Carrying out a factory reset will also erase any internet radio station presets and other preferences that you may have previously stored.
Comments
