What do the scaling options (Processed and Pass Through) in the CXR's Input Setup menu do?
When set to Processed, the CXR will upscale 1080p images to 4K resolution, if connected to a 4K compatible display.
Please note:
- If a 4K TV is not being used, then the CXR will ignore this setting and just pass through the original image.
- If the input resolution is lower than 1080p (e.g. 1080i, 720p, etc.) then the CXR will ignore this setting and just pass through the original image.
1 out of 1 found this helpful
