How do I save a radio station on my CXN?
- Open the Cambridge Audio Connect app
- Then select 'Radio' which is located under library
- You then search for the station you are looking for
- Once you've found the station, click on it and you will then see the option to 'add preset'
- Select which preset you wish to replace and save
2 out of 3 found this helpful
