If you wish to connect the CXN to one single device, you can use any output, digital or analogue, that you wish.
If however, you would like to connect the CXN to more than one device at a time, you can connect up to 4 devices and play simultaneously. This is especially beneficial if you are using the CXN in Digital Preamp Mode and Bi-Amping.
