How do I switch on my amplifier with the CXN or the Connect app?
To switch on your amplifier using the CXN, you must have Digital Pre Amp Mode enabled* and have the CXN connected to the amplifier via the control bus cable. The control bus cable should run from Control Bus Out from the CXN to Control Bus In on the amplifier.
Then, using the Connect app, front panel or the remote control, you can power the CXN on and off **.  This will in turn send the power command to the amplifier which will switch on or off with the CXN.
 *Digital Pre Amp mode must be enabled, to ensure that the volume is not set to maximum if being used in conjunction with a power amplifier.
** To power on and off using the Connect app, the CXN must also be in 'Network Standby' mode, allowing it to remain visible on the network for the app to 'see it' in order to power it up
1. Navigate to the menu button on the bottom left corner of the Connect app.
2. The CXN which is connected to the app will show with a tick. Press the power symbol in the top right corner of the app to power the player off.
3. To switch the player back on, navigate to the same place and selecting your player will show the message: "Do you wish to exit standby mode?" Select Yes to wake the unit up.
