Will I be able to use the Stream Magic (eg. Spotify or UPnP) source in Zone 2 on my CXR200?
The FM/AM Tuner and Stream Magic Sources are stereo and can always be played in Zone 2.
Note: The 'Stream Magic' source is our network streaming module. This is selected as a single source on the CXR, but is made up of different inputs including Connect UPnP, internet radio, USB, BT100 and Spotify, and is controlled using the Cambridge Connect app.
You can listen to the same Stream Magic audio in both zones, but you cannot split the source and listen to a different Stream Magic source in each zone.
1 out of 1 found this helpful
