To play Spotify content on your CXN, please follow these steps:
1. Open your Spotify App and select your desired media.
2. Connect to the Network Player using the Spotify 'speaker' icon.
3. Spotify should begin playing on your CXN.
If you then wish to save a Spotify playlist, album or 'Artist Radio' as a preset on your CXN, this is also possible. Begin playing your chosen playlist, then using the front panel interface select the Presets menu and select [Set Preset].
Finally, select the preset number you wish to save the playlist as and your Spotify playlist should now be available when you select this preset number.
Please Note - When connecting for the first time both the mobile device and CXN will need to be on the same network in order for the CXN to be discoverable within Spotify.
