How do I remove and rotate the Minx Min 22’s front grille when using it as a centre speaker?
To remove the front grille from the Min 22, simply insert the edge of a credit card (or equivalent) into the space between the grille’s outer edge and the Min 22’s inner rim.
 Using the rim as a pivot point, apply pressure to lift the grille.
 Once the grille has been removed from the Min 22, simply rotate the grille and press back onto the Min 22. The grille will click into place in the new position.
2 out of 3 found this helpful
