How do I disconnect my TV/Sky remote from my TV2?
The TV2 supports IR learning. This means the TV2 is able to learn the volume commands from your TV or Sky remote.
However, should you wish to reset the TV2 and disconnect your television or Sky remote please follow the simple steps below:
  1. Put the TV2 in standby mode. This is done by powering down the TV2.
  2. Press the VOL + button on the TV2 remote 3 times in quick succession (LED light should flash Red)
  3. Hold the VOL - button on the TV2 remote for approx 3 seconds (LED light should flash White).
The TV2 will now have been reset and will have removed your TV/Sky remotes IR commands.
1 out of 1 found this helpful
