I have synchronised/paired my second (slave) G2 speaker to my first (master) G2 speaker. How do I synchronise/pair to a different G2 master speaker?
Once a G2 speaker has been synchronised/paired to another G2, it remembers the identity of its master and will auto-look for it each time it is powered up in slave (B) mode. However it could arise that you want to pair to a different master at some point, so this 'memory' would need to be flushed from the slave (B) speaker.
It’s quite simple to do:
- power the slave (B) speaker up as normal in 'B' mode
- toggle the rear panel switch from B-A-B
- then double press the Bluetooth button to activate 'syncing' mode and pair to a new master (A) speaker in the normal way.
