BT100 firmware upgrade:
Fixes issue when playing Bluetooth audio from some aptX enabled devices.
This affects some(but not all) BT100 units.
The symptom is audio cutting out after 3 minutes of playback with some aptX capable source devices.
If you have any previous version of the update app installed on your PC, you should uninstall this first:
Windows 7 / 8 - ‘Control Panel → Programs and Features’ and double clicking on any installed instance of ‘BT100 Update’.
Windows XP - ‘Control Panel → Add and Remove Programs’ and double clicking on any installed instance of ‘BT100 Update’.
Full instructions from a fresh install are then included in the zip file below; please read them first.
Please note: this upgrade can only be carried out on a Windows computer.
