What CAT5 is best for an Incognito installation?
Generally we would recommend unshielded, multistrand CAT5 for Installation work as it is easiest to use. Shielding should only be considered if the CAT5 is being run next to power lines or similar. There is no performance difference between multi strand and solid core cable but solid core is significantly harder to place into an RJ45 plug.
