What does it mean if there is no Composite or SVHS output from the connections on the rear panel?
The Composite and SVHS outputs will only output a signal if these are connected to a screen or monitor before the 640H is powered on. If there is no physical video connection between either ot these outputs and a monitor at the point when the unit is powered on, then these will not output a signal, and only the Pc VGA output will function.
