Can I play my iPod into the DacMagic / DacMagic Plus / DacMagic 100 / 851D / 851C
No, the iPod itself does not output a 2 channel PCM audio signal over USB.  If you want to connect your iTunes library to the DAC you would either need to connect your computer via USB/optical/coaxial to the DacMagic or use an iPod dock that allows a digital output from the iPod such as the iD100
