How do I re-activate the Easy Set-up Wizard if I have already been using the 650BD?
The Easy Set-up Wizard is activated automatically at initial power up when the player is first switched on, or if required it can be carried out again by resetting the factory defaults in the 'Device Set-up' menu.
Please note that resetting factory defaults can only be done if there is no disc in the player or other device connected to the player.  If there is a disc in the player, then 'Reset Factory Defaults' will not appear in the 'Device Set-up' menu.
