Does the NP30/Stream Magic 6 have a factory reset?
Yes, there are two ways to factory reset the NP30/Stream Magic 6 - both methods achieve the same result.
The first option is to simply select 'Factory Reset' in the Stream Magic 6 / / Minx Xi / NP30's Settings menu.
The second option is to power on the device from Standby with the select knob pressed in.  Keep the knob pressed in until 'Factory Reset' appears on screen.
0 out of 1 found this helpful
