Can I use the Cambridge Audio USB Class 2 driver with my DacMagic?
The USB Class 2 driver is designed to enable ASIO connections and 192kHz file replay. This driver is supported by the DacMagic Plus, DacMagic 100, DacMagic XS, Stream Magic 6, 851C, 851D, 751R.
The older DacMagic (2008 - 2011) uses a simpler USB connection that is not compatible with this USB driver.
0 out of 2 found this helpful
