Why can't I access close captions with my Blu-Ray player?
Closed captions (which are distinct from subtitles and employ their own software to function) are frequently not compatible with the HDMI standard. As such, you will need to connect your Blu-ray player using the component video outputs for the closed captions to be visible. Given that this is a function generally only found on DVD's, there will be no loss of resolution.
