Is there a crossover frequency on the pre-out of Cambridge Audio amplifiers?
The pre-out on Cambridge Audio amplifiers does not have a crossover applied to it, This is because the output is also fitted with a view to being used with a power amplifier which will need the full frequency to be sent to it. If you are connecting your subwoofer, you will need to set the crossover on the sub itself. This should be done by noting the frequency response of your speakers and carrying out experiments from there.
2 out of 2 found this helpful
