Why do the sampling rate lights on my DacMagic not change if I stream high resolution audio or forced upsampled audio via an AirPort Express?
If you are streaming audio via an AirPort Express, the maximum sampling rate from the optical output is 44.1kHz. If you stream high resolution audio through the AirPort Express, it will be downsampled to this sampling rate and this will be reflected on the sampling rate indicator of your DacMagic.
